5w20 and Oil change
Old May 24, 2011 | 04:51 PM
  #31
Every member on here will have a different opinion about motor oil.
As long as you change the oil at the proper interval, use the proper weight oil, and the oil has the API seal of approval on it, then you should be good. Also change the oil filter at the proper interval.
Check the oil level whenever you fill up, because low oil can cause engine damage.
Old May 30, 2011 | 09:15 PM
  #32
Accord Owner's Avatar
I change it every 3K miles. I use to use 5 quarts and someone said 4 should be the right amount. I change the oil filter with my oil change every 3K miles.
JonJon13926
Apr 16, 2013 09:20 PM
piggylover1985
Jun 9, 2011 05:47 AM
chris h
Apr 3, 2011 10:01 AM
stevemacleodns
Oct 29, 2008 12:29 PM
superballz00
Nov 12, 2007 10:55 AM
