6th gen?
Old Aug 26, 2011 | 09:23 PM
number8's Avatar
Default 6th gen?
i bought an 01 accord recently and i just noticed that the space between the left rear wheelwell and tire is like an inch less than the one on the right. i checked for a broken spring but didn't see anything broken. i then looked at my moms 07 accord and its the same. is this normal?
Old Aug 27, 2011 | 06:01 AM
piggylover1985's Avatar
Good question, i noticed that too, about 1/2" difference, but i though it's because of my uneven driveway.
Old Aug 28, 2011 | 10:23 PM
It's really really common for driveways and garage-floors to have some twist. They slopw down to drain rainwater. Check to rule that out before you assume it's the car.
Old Aug 30, 2011 | 10:34 PM
number8's Avatar
yeah. i triple checked it on all kinds of surface, including my garage which is flat. what could it be worn/broken spring? bent control arm?
Old Aug 31, 2011 | 05:10 AM
I talked to a few tech about this, and they all thinking that could cause by worn/weak spring.
Old Aug 31, 2011 | 10:37 AM
Another thing to check... Is there a similar difference between the front wheels?
Generally the roll-stiffness of the front end is greater than that on the rear. Certainly that's the case for stock suspension. So the front wheels have a "stronger" ability to control how the car leans. So a weak spring in the front is more able to make the car lean to one side. You can prove or rule-out weak springs by measuring corner-weights.
If the garage floor is truly flat (got a surveyor's transit?) then what you see at the rear might mean the structure of the car body has a twist in it. Don't panic, that's more common that you might think. But really I'm more skeptical about the floor being flat.
Elk Hunter
Oct 2, 2012 11:08 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
finch13
Apr 15, 2008 10:13 AM
bigdog1428
Dec 19, 2006 09:07 AM
