6th Gen 5 Speed Swap Wiring
Old Aug 29, 2012 | 11:48 PM
SuperMidget's Avatar
Default 6th Gen 5 Speed Swap Wiring
Hey there guys, I'm new here, finally joined up.
Been a member of 6thgenaccord.com for a couple years now, I have an 02 Accord SE 4 cyl Auto. I have 80% of the required info and parts to do the job, and done tons of reseach (also have a h23a dohc vtec head I stumbled across for 100 bucks... but that's another thread).
The wiring is what is very unclear on these forums, now I found this one (As well as the two on 6thgenaccord's forums, which are much worse):
honda-tech.com/showthread.php?t=1229014
which is AMAZING. but people have posted that the wiring colours he gives doesn't match up and so on... Also he doesn't specifiy if he is repining for a 5 speed ECU or for the stock Auto ECU.
As I would like to keep the stock ECU if possible until the H23 Head goes on a little later down the road, I need to know if I this DIY guide is based on him using his stock 6th gen auto ecu or not (or if this even matters.. lol)
Thanks guys, hope I don't **** anyone off too bad.. Lawl
Old Aug 30, 2012 | 12:08 AM
Haaa answered my own question:
Found this:
(Where "PRELUDE" refers to a full h22a with 5 speed swap in a 6th gen )
You will need to rewire the car to use the prelude vss, just splice the prelude vss harness onto the accord harness and plug it up to the prelude vss. Then tap the output wire from the ecu to the tach into the input wire that goes into the ecu. This allows your speedometer to work properly.
You can close this Good to keep in the google banks tho!
grim_reaper
Feb 23, 2012 09:04 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
finch13
Apr 15, 2008 10:13 AM
bigdog1428
Dec 19, 2006 09:07 AM
