86-89 accord tips
Old May 1, 2007 | 02:11 PM
Blunt
Default 86-89 accord tips
just putting my 89 accord back together.... from clutch replacment ... seem to be having trouble getting ball joint back into place any tricks or hints? .... also wondering about the starter seems to be dead i hook it directly to 12v power and no response should i head out to the wrecker for new starter? .... thanks for any tips and help
Old May 1, 2007 | 02:43 PM
Blunt
Default RE: 86-89 accord tips
phoned a wrecker that removes stuff and sells it to you they asked if its a 5 speed or auto ........ is this really relivent? .. i know of pic your own part wrecker that would be a lot cheaper but all they have is automatics ...... should i just get one via cheap or do i have to go the expensive way?
Old May 1, 2007 | 10:51 PM
Blunt
accord is back together still havent got the ball joint to go
back together right.. and bought the expensive starter .. still wont start via key .. is this some other issue not related to the starter? push start till get starter to work right any suggestions or help would be greatly appriciated
Old May 5, 2007 | 03:39 AM
Blunt
ok never mind i'll figure it out my self
Old May 16, 2007 | 10:31 AM
Blunt
still no starter bench test should prove if starter works right?
Old May 16, 2007 | 06:08 PM
Yes bench test will give you your answer,
scorpiodman
May 21, 2010 01:03 PM
FinleyRacing37
Apr 29, 2008 10:37 PM
JohnnyWadd
Oct 1, 2007 05:56 AM
awardblvr
Jul 31, 2007 06:24 PM
fperezal
Jul 29, 2007 08:33 PM
