89 2.0 L cold weather starting problem
Old Dec 2, 2011 | 07:49 PM
larry in bc's Avatar
Default 89 2.0 L cold weather starting problem
I have an 89 2.0 L, carbureted, manual trans. In cold weather ( -5 deg. C )
or colder, I have intermittent starting problems. It turns over and won't fire. It sounds like it's not getting fuel. It has a new fuel filter, plugs, cap and rotor. It also occasionally idles very high ( up to 3,000 rpm ), but also just in cold weather. I replaced the thermostat and seems to have helped the idle issue, but I'm not sure if it is completely solved. Any ideas??????
Old Dec 2, 2011 | 09:33 PM
Are you sure the choke is set properly...remember since it is a carb, there is fuel in the bowl......
Idle, does it go down on its own...these darn things will cold ilde at something like 2,500....now if it hangs there then I would look into the fast idle unloader....check the manual for how to test....I'd offer a new choke stat but someone in Canada stole mine.........Lee B, he lived in the Vancoover(? I can't spell) area
ArcticHonda
Nov 24, 2023 05:03 PM
d0n
Dec 10, 2014 07:42 AM
Railey
Feb 18, 2011 02:42 AM
LaurenK
Sep 29, 2009 07:56 PM
AccordEX
Dec 4, 2006 02:09 AM
