89 Accord A20A1 problems
Old Aug 24, 2011 | 09:18 PM
1) just above the oil filter. Jack the car up, use stands to spport the car, just above the oil filter, below the intake there is a one wire "switch/sensor".
2 & 3) Well should have thought about that more, sorry. The "silver" hose will slip out of a bracket and give a little more room. However that bracket will take a bit of skin if you are not careful....and that silver hose is the "preheater" hose so you can't really hurt it....then the lower rad hose should move to the pass side a little and allow room?
Then the next question will be the threaded "stick". If that bogger is in there tight, well I can help you make a "tool"....18 to 24 inch long (?) 1/2 diam black pipe from you favorite home improvement store, cut a slot in one end, big engough to fit over the "slot" of the "stick". A reverse slotted screwdriver, if you get what I mean. Then slip the pipe on the stick and use a wrench to "spin" the pipe.
How about we start with the throttle cable?
Old Sep 3, 2021 | 06:19 PM
Longd24's Avatar
Default We replaced the engine from a a20a1 to a any 20a1 put a 88 trans onn
Okay from a cold start return the key and we hear this loud banging cranky f****** awful noise and we don't know where it's coming from if I was good transmission good we're just not sure where this noise is coming from can someone give us some direction
ncbkr2002
Aug 10, 2014 05:55 PM
fotosoup
Nov 29, 2012 08:45 PM
ndblacknight07
Jun 26, 2012 10:18 AM
Da Flash
Jun 14, 2011 01:56 AM
ncbkr2002
Nov 8, 2009 07:36 PM
