89 Accord A/C Compressor
Old May 14, 2018 | 09:09 PM
weedog's Avatar
Default 89 Accord A/C Compressor
Is There anyway To Tell If The A/C Compressor Is Bad On My 1989 Honda Accord Without The A/C Belt On It. Can I Turn The Clutch On The Compressor Without The Belt On It. Thanks
Old May 15, 2018 | 06:18 AM
Without power or a belt, the compressor pulley should just spin freely. But the hub of the pulley won't spin with it.
If there's a way to grab the hub of the pulley, that will spin the compressor. See if it turns. Some resistance from the compressor turning but you should be able to turn it if you can grab something. Usually there's something there you can grab, but I'm not real familiar with that compressor.
Or look for a single wire coming from the clutch. Apply battery-voltage to that wire, maybe a jumper from the battery. That will engage the clutch so the pulley will be locked to its own hub and you can spin the compressor by spinning the pulley.
Let us know how each of these works out.
ak474u
May 4, 2015 11:15 PM
Walt
Jul 1, 2008 10:51 PM
Gastongo
Feb 25, 2008 05:03 PM
jamoke59
Nov 21, 2007 10:41 PM
Lew
Jun 23, 2007 11:20 AM
