89 accord LXI camshaft replacement
Old May 5, 2017 | 01:18 PM
Ken89accordlxi's Avatar
Default 89 accord LXI camshaft replacement
I have an 89 accord LXI with the 2.0 12valve Engine. The camshaft is broken and needs replacement. I found one on rockauto but it says the fitment is only for the DX model. What's the difference when it comes to engine components? Could I use the cam for the DX mode in the LXI? Also, when I'm in there replacing the camshaft, what other things should I check and replace? Valves, bearings, seals?
Old May 6, 2017 | 06:08 AM
The spec's are different - lift and that. I honestly don't know what difference it will make.
Me I'd be concerned with "why" did it break?
If you have the means, I would pull it and have a machine shop check/rebuild it.
Sundevil81
Sep 20, 2012 08:09 PM
csr1138
Jun 10, 2011 07:18 AM
88lxaccord3152
May 4, 2009 08:28 PM
Handiman1
Sep 24, 2006 06:38 PM
deserthonda
May 12, 2006 12:12 AM
