89 accord overheating
Son called me said the car was steaming.Told him to shut off.Had a look low on coolant,topped up and got home.Check and fans not coming on at hot temp,Changed sensor still no difference,but found crack in top of Rad.Changed Rad today and thermostat and fans still don't come on.Ran wire from where sensor plugs in (jumper ) and fans kick in(second sensor)Can't figure it out any help would be great Thanks Rick
ORIGINAL: stoneman
Have the rad sensor jumpered and it works,what other sensors are there,I dont have a wiring diagram and cant find one for the cooling system.Thanks Rick
if the top hose is cool or warm , while the bottom is hot , than you got a stuck closed t-stat ( t-stat located on top hose )..
Joshporsche
Jun 14, 2006 10:07 PM
copa708
Apr 24, 2006 08:36 PM
