89 Honda Accord - Conditional Starting Issue
1989 Honda Accord - Automatic - Fuel Injected;
This car is a mystery to me. When the weather conditions are too extreme (hot/cold) the vehicle tends to have difficulty starting. The engine turns over, but does not catch. I've been down the road of the basic diagnostics, replaced the "quick fix" parts, 02Sensors, Relays, Spark Plugs/Wires, etc. and still find myself sitting in the heat with my head on the steering wheel. My suspicion is that the increased (when hot) and decreased (when cold) pressure in the system, is affecting the fuel pump. But then, I'm more IT than Mechanically inclined. Any/all information would be greatly appreciated.
Happy Fourth!
Happy Fourth!
This sounds like a main fuel relay. Not sure if you replaced that yet.
Here is a simple test. Turn the key to the II position, but do not try to start the car. While the check engine light does the bulb check, you should be able to hear the fuel pump turn from the back seat area. Turn off the radio, blower, etc and listen carefully, because the sound is a faint buzzing/whirling sound.
That sound should be present when the car is starting. Get in the habit of listening for this sound. Let us know what you find when the car is not starting.
If this is an 89 Accord and does not have a main relay then you have a DX/LX model with a carb.....totally different.
If your car is a DX/LX - has a carb - then I suggest you start your own thread and give the details of the issue you are having.
I thoroughly enjoyed being an Honda owner. I can quite easily by-pass the single issue that offset the car (being the inconsistent starting) and recognize the features of a well crafted vehicle. I purchased the 89 Honda Accord from a professional gentleman who said he was all set attempting to diagnose the vehicle, it being over twenty years old.
