90 Accord DX manual 2.2 jrjjr67
Old Mar 21, 2011 | 10:20 PM
jrjjr67's Avatar
Default 90 Accord DX manual 2.2 jrjjr67
Ok, I am lost. I can get the car to turn over, but not run. I have replaced the ECU, Coil, main relay, igniter, spark plugs, and distributor. I have checked the DC/CYL/Crank angle sensor and it reads good. I can hear the fuel pump when I turn the car on and have even smelled fuel on the plugs after turning it over. It has spark to all 4 wires, but wont even kick with starting fluid. I'm going crazy (and spending a lot) but am at a loss. Any help would be appreciated! Thanks
( I was told the timing belt was replaced 6 months ago)
Old Mar 22, 2011 | 07:08 AM
Check for error codes?
Measure compression?
Old Mar 22, 2011 | 07:16 PM
jrjjr67's Avatar
Thank you. My book says to use a paperclip to access the error codes by reading them off of the check engine light. When I do this, the check engine light just stays on and does not flash any codes. I will try the compression.
Old Mar 22, 2011 | 08:19 PM
Do you have the spark plug wires hooked up in the correct order on the distributor cap? The firing order is 1, 3, 4, 2.
Start at #1 when facing the distributor from the passenger tire, the next wire clockwise should be #3, then 4, then 2.
If you have a Honda distributor cap. the #1 post has a mark.
Old Mar 23, 2011 | 09:46 PM
jrjjr67's Avatar
Thank you. i do have them in the correct order. I plan to put in a new fuel pump this weekend, I will see if that gets me anywhere. Thanks again.
Old Mar 24, 2011 | 06:12 PM
Why the new pump? Are you not getting fuel to the injectors?
Old Apr 1, 2011 | 07:49 PM
jrjjr67's Avatar
Thanks for all of your help! It seems that I sheared off a pin that allowed the timing to jump off. I adjusted it back and it started right up. It runs good until warm, then the timing jumos off. Any ideas? Thanks
Old Apr 1, 2011 | 08:35 PM
What pin did you shear off?
cliff
Apr 15, 2013 02:27 PM
Pajamarama
Jul 28, 2012 01:15 PM
Max Utility
May 19, 2011 12:32 AM
saanich
Sep 29, 2009 02:41 AM
