91 accord; gas leak?
Old Sep 15, 2011 | 05:32 AM
jackfast's Avatar
Default 91 accord; gas leak?
my MPG has plummeted and when the windows are rolled up, i smell gas. how should i go about investigating for leaks? is there any particular place that is most suspect? thanks.
Old Sep 15, 2011 | 07:42 AM
I'd check the fuel tank & connections. Not sure the best place, but first try removing the base of the rear seat & look for covers bolted to the floor. Might be located on the floor of the trunk, way forwards near the seatback.
The steel fuel lines run underneath the floorpan, but when they corrode & leak maybe the smell can get into the cabin.
Old Sep 16, 2011 | 10:22 AM
onmyownaccord's Avatar
Jackfast,
I would inspect your fuel return pipe (ref #15 in this '91 Accord Fuel Line diagram) to see if there are any noticeable leaks along the entire pipe line. I've seen leaks arise in this pipe in more than a few older Accords.
Also, scrutinize the fuel filler pipe for any leaks as well
Old Sep 16, 2011 | 10:34 AM
Fuel injector to fuel rail orings can age/leak. Difficult to see, but easier to smell.
Old Sep 16, 2011 | 10:54 AM
And it's warm, so it evaporates as soon as it leaks.
Old Sep 19, 2011 | 06:18 AM
jackfast's Avatar
replies are appreciated! i am on it.
blai3ser
Nov 26, 2010 12:34 PM
bjr001
Nov 25, 2010 12:05 AM
EBK142
Jul 20, 2009 09:10 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
BostonPuppyDawg
Oct 3, 2006 01:24 AM
