91' accord ECU location
hey genius, i did search "ecu" and got "0" matches. so. calm down. "senior member/forum monitor" does not make you cool or smart. just pathetic. get out of your moms basement once in a while and join the living. thanks again for your harsh reply you sad, sad little man...
First off, like PA said , that is part of his signature (IT is also in my signature ), meaning it appears all the time . it was not meant for you at all......the reason is ,, that many, many members are too lazy to look up things themselves so they just ask ,so someone else has to do the looking up for them, this happens over and over and over and after a while it gets tiring to keep on saying ,,,, the answer is in the DIY section did you look there ?? ,,,
Secondly, there is no need to attack a member personally ,,this WILL NOT be tolerated at all.not by you or anyone else . you should apologize to him and thank him for giving you the correct reply ,instead of jumping the gun such as you did ..,,
You are welcome here and we will help you should you need help,, as long as you show respect for all members , if you do not like to comply with that you will not be welcome to this forum again ..
Anyway,, like he said,, ecu is rt side under the carpet passenger feet , pull back on the carpet and you will see it
But yes my sig does go out to ppl like you. You can't search be4 you post. Like deserthonda said your answer is in the DIY part of the forum....but I was nice enough to answer your question anyways. So get your facts straight be4 you run your mouth son.
Also thank you deserthonda and PAhonda
live2rice
Sep 20, 2012 02:26 PM
