91 Accord having trouble starting but eventually starts and runs...
Old May 25, 2012 | 03:53 PM
Injun Joe's Avatar
Default 91 Accord having trouble starting but eventually starts and runs...
I have a 91 Accord, 2.2L that has trouble starting, when it's cold it turns over and over and I have to hold the key in starting position for like 10 seconds for it to fire up, when it does fire up it has a low idle for a few seconds then it starts running fine, when it's running there's no missing or anything...If i turn it off then start it up again it starts fine, this only happens when the car has been sitting for a little while...Any suggestions?
Old May 25, 2012 | 05:45 PM
crispin's Avatar
Do a search on here for "main relay" and follow the tests it gives you.
Then report back your findings to this thread.
Also pull your ECU codes and report those back here as well.
You can find how to pull those in the DYI Answers section of this forum.
TTYL after you have done those 2 things.
Old May 26, 2012 | 07:10 AM
One I'd like to add, does the "speed" of the starter seem to be different. Meaning on this cold start, is the starter spinning the motor slower than the other times?
SaveTheManuals
Jan 26, 2015 12:17 PM
handygoat
Jan 22, 2015 05:43 AM
Isengard2216
Nov 28, 2014 11:55 AM
Daily Cruiser
May 10, 2012 08:41 PM
era7777
Sep 2, 2011 04:12 PM
