91 Accord Ingnition Lock Cylinder
Old May 3, 2007 | 04:39 PM
oldsbill
Default 91 Accord Ingnition Lock Cylinder
My son has a 1991 Accord with a soon to be worn out ignition lock cylinder.
My local Honda Dealer says that it is impossible to replace the lock cylinder with one that will use the same key as the doors and trunk.
Can anyone confirm that this is the case.
Otherwise I will get a jobber lock and carry two keys, one for ignition and one for the doors and trunk.
Thanks for any replys.
Old May 3, 2007 | 07:50 PM
sir_nasty's Avatar
Default RE: 91 Accord Ingnition Lock Cylinder
It's not impossible but it's probably a little spendy.... call a local locksmith and tell them your situation and I'm sure they can find a way to make it so you can use the same key.... I think that in some cases they can kind of "rebuild" your existing lock mechanisim..... talk to them about prices/options and I'm sure you can get something, otherwise yes you will have two different keys
Old Jun 12, 2007 | 02:58 PM
getatjbrown's Avatar
What makes u think it is worn out? Does the key not come out when put in park?
If so, its probably your switch position sensor on the gear selector.... much cheaper and easier to fix
Old Jun 12, 2007 | 03:38 PM
deserthonda's Avatar
we do this all the time when we have to replace the ugn switch and customer wants to use only one key,,
Take the new ign switch and the old key to a lock smith and ask them to rekey the NEW IGN switch to the old key ,, so 1 key will open doors and start the car 50-60 dollars ..
Chris Jameson
Feb 19, 2013 06:39 AM
onequickhonda
May 14, 2010 02:47 PM
STINKA621
Mar 9, 2009 07:53 AM
OlBlue
Jul 1, 2008 02:16 PM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
