94 Accord Ignition Lock Cylinder Replacement
Old Jul 1, 2008 | 08:21 AM
OlBlue
Default 94 Accord Ignition Lock Cylinder Replacement
i have a 94 accord that eats key switches for lunch. THis will be the third switch in 2 years on this car. It will lose all power and die and not crank back up. I have figured out this morning that if i turn it over and then wiggle the key right it will stay running, but i must hold pressure on the key in the run position.
My question is: is this a replacement i can do myself, and does anyone have tips or instructions on the removal and installation of the lock cylinder.
Thanks Cory.
Old Jul 1, 2008 | 12:52 PM
Default RE: 94 Accord Ignition Lock Cylinder Replacement
See attached link.
http://www.tegger.com/hondafaq/ignit...tch/index.html
I've heard that carrying a large heavy set of keys on the keychain can hasten failure of the keyswitch assy. Could this be part of your problem?
Old Jul 1, 2008 | 02:16 PM
OlBlue
Thanks for the link. Yeah the key chain could be my problem also now that i think about it and my main key is badly worn. I am going to replace just the switch first and then if that hasnt cured my problem then ill swap out the lock cylinder. i tried my spare key and it fits much tighter in the cylinder than the original. The explination of the pitting problem sounds exactly like what i am dealing with. Thanks again for your help.
Mic-Ill
Feb 9, 2013 02:36 PM
wings
Jan 19, 2011 09:06 AM
wings
Jan 3, 2011 03:18 PM
accordfan
May 16, 2010 09:33 PM
banditrider
Aug 4, 2008 03:20 PM
