91 Accord won't start, won't crank, full dash lights..
Old Jun 17, 2015 | 12:21 AM
Sheri6889's Avatar
Default 91 Accord won't start, won't crank, full dash lights..
I have a 91 honda accord that was driven parked and about an hour later will no longer do anything.. When you turn the key full bright dash lights, but that's all. No sound just nothing.. I had the starter checked it's good. That Mechanic said it's electrical, and left. I'm not sure how it could be related but the only thing wrong recently has been it's hard shifting especially into third.
Old Jun 17, 2015 | 08:19 AM
You need a test light to check whether 12V starter signal (small blk/wht wire) is getting to starter.
If yes, then starter is problem. If no signal, then ignition switch electrical assy, ignition system fuse (fuse 9 under dash), neutral safety switch (auto) or clutch interlock (manual) is open. Testing required to determine which.
Report what you find for additional help.
laonda
May 27, 2015 12:55 PM
ThatOneAccord
Aug 15, 2011 02:01 AM
Vettress
Jul 7, 2010 11:10 AM
dimbee
Oct 12, 2007 02:52 PM
marky4
Sep 7, 2006 01:25 AM
