91 honda accord running poorly
Old Sep 14, 2012 | 12:16 AM
Horn E Toad's Avatar
Exclamation 91 honda accord running poorly
i had a problem with engine performance when holding accelerator steady at 3k RPMs...the car would bog down after 30-45 seconds...and also when driving....after CEL came on car would run better but still lacked power....i pulled code 43 off the ECU...Researched and seen its for Fuel System Supply...but i read forums that say o2 sensor was problem.....I replaced o2 sensor and reset ECU...No more codes and also car doesn't bog down if held steady at 3k RPMS...But car still lacks power as if riding the brake....but that's not the case..also idle is bouncing between 500-750 RPMs..I would appreciate any advise/feedback
Thanks
Old Sep 14, 2012 | 06:46 PM
Are the tune up items up to date - cap, rotor, plugs, inspect wires?
Can't hurt to clean the TB and IACV as well.
How does it preform when cold?
Old Sep 15, 2012 | 07:52 AM
when cold it starts fin only thing is that belts squeel until engine is warm
Old Sep 15, 2012 | 11:02 AM
Inspect the belts for wear and proper tension.......what about the tune up items?
Old Sep 15, 2012 | 10:48 PM
Default re:
i the process of tune up....so far i've done filter changes oil change, plugs, cleaned EGR, replaced o2 sensor, was goin' for cap, rotor, and wireset next...i was thinking maybe cat converter could be clogged going to drill hole in front of it to see if it makes a change....
Old Sep 15, 2012 | 10:50 PM
whats the best way to test cap and wires?
Old Sep 16, 2012 | 09:06 AM
If you are not sure when the cap/rotor were last done - replace them, at least you have a baseline for when they are do. You can check the wear on the contacts, look for any "tracking" marks ect....but they are maint/wear items.
The wires, test the resistance. Then inspect the outer cover for cracks or tears.
Do you have a timing light ?
Also, one thing - kind of sounds like the car is "new to you", this is why I'm trying to rule out normal tune up/maint items.
Old Sep 18, 2012 | 12:10 AM
actually yea car was bought a few months ago now i'm learning about my bad investment so to speak, but i know that TLC and i'll have a good car for maybe another 100k miles, interesting new development today though.....CEL came back on and i checked ECU again and code 43 is back....i'm smelling un burnt gas also...pretty sure it's something to do with fuel suppy....just not sure what....going to clean IACV tomorrow at work.....
Old Sep 18, 2012 | 12:22 AM
and no timing light but i'm probably going to pick one up at harbor freight
stubby1962
Mar 13, 2013 08:31 PM
jethro
Sep 19, 2011 06:05 PM
90accord90
Jan 25, 2010 03:28 PM
rda
Jul 21, 2009 06:29 AM
rikleo2001
Jun 8, 2009 12:58 PM
