'92 5 speed accord. Clutch starting to have issues.
Old May 16, 2020 | 04:28 PM
blob gnarly's Avatar
Default '92 5 speed accord. Clutch starting to have issues.
My clutch is having some difficulty in the lower gears. Especially going up hills.
250,000 miles on it. Not sure if or when the clutch was ever replaced.
What am I looking at in terms of getting it fixed?
Old May 16, 2020 | 05:59 PM
The pressure plate and clutch friction material would need to be replaced. The hard part about the repair is having to remove the manual transmission from the car.
Ericthecarguy had a video for sale on his website that covers replacing the clutch that covers the 90s accords. It is a very detailed step by step procedure and would be useful if you plan a DIY repair.
Old May 17, 2020 | 11:03 AM
What way is the clutch "having some difficulty"? PA's answer is for the clutch slipping (RPM suddenly increasing without the car speeding up). To be fair, that IS the most common thing.
If it's something else, please describe what it's doing.
Old Jun 16, 2020 | 08:33 PM
Yes it's slipping on shift and accelerating. RPMs go way up if I keep my foot on the pedal.
I have to back of on it until it finally shifts into gear, but it's just barely making it. Really
slow and weak power. On freeway it's fine once I get up to 60.
Old Jun 16, 2020 | 10:36 PM
UhOh's Avatar
So parts wise, you would buy the pressure plate and the clutch plate. When I last replaced a clutch, long time ago, I also replaced the throw-out bearing (not expensive) which is right there as part of the functioning clutch mechanism.
I've a '92 manual that's also a keeper. Luck.
Old Jun 16, 2020 | 10:45 PM
UhOh's Avatar
Originally Posted by blob gnarly
My clutch is "Clutch starting to have issues."
Actually, the wording suggests that you might believe you have time to address this issue.
But slipping clutch is a very near term repair need; quite soon / anytime the clutch plate will be totally friction gone and
you'll be stuck in traffic on a bridge somewhere unable to move when traffic starts moving. Suggest: park the car until it's repaired.
Old Jun 17, 2020 | 12:36 PM
The Toecutter's Avatar
I agree 100% with this ^^. And at 250K miles, it's probably due for replacement.
crshbandit
Jun 14, 2011 04:54 PM
BuckNasty
Aug 18, 2010 10:53 PM
Jmoney
Jun 8, 2009 08:43 AM
bpo145
Nov 20, 2006 03:07 PM
tamb
Jul 21, 2006 01:05 AM
