92 Accord 4 dr LX 4AT Timing belt job
Tony (or anyone),
How did you get the small pulley off to get to the crank seal? I am having the hardest time getting the pulley off.
Thanks
EDIT: I got it off finally. I used a torch on it for a couple of seconds and the pully slid right off.
Thanks
Well, Im doing the Timing belt Job. Im stuck at the Crank Pulley Bolt. I'm using a Electric Dewalt Impact with a 19mm socket. I put the impact on reverse and hit the button aleast 5 mins and it wont come off. Is there anything I can do to loosing it up?
Thanks
Anthony
Thanks
Anthony
hey try this http://www.amazon.com/o/ASIN/B0000TM...298828-6159005 has good reviews man. let me know if it works
Tony, I noticed in your pictures your car does not have the retainer for the Oil seal , Balance shaft seal.
Did you ever think of getting one of those ? did you install one after you took the picture ?
There was no retainer on the car when I took thelowercover off for the first time.
I installedtheretainerafter Ireplaced the oldseal with a new one.
