92 accord battery hooked up backwards
Old Dec 29, 2012 | 08:00 PM
johnrehder's Avatar
Question 92 accord battery hooked up backwards
Hey all,
My son hooked up his battery backwards and of course got a nice spark as a result. The car now has no power to anything. The battery is fine, is there a fuseable link or relay that needs to be replaced to get power back? If so where would it be located. Tried the search but didn't get anything. Thanks for any advice.
Old Dec 29, 2012 | 08:38 PM
Check the large fuses in the under hood fuse box.
Fuse no. 15 (80A), alternator, power distribution (main fuse) is probably blown. Also take a look at fuse no. 19 (50A), ignition switch (BAT); but, it probably is just no. 15 that is blown.
To replace the large fuse requires a Philips head screwdriver. Leave the battery disconnected while replacing the large fuse(s) to prevent accidentally bridging the connection with the screwdriver.
See my post in this thread for the fuse to check.
https://www.hondaaccordforum.com/for...its-new-52081/
Old Dec 29, 2012 | 08:44 PM
johnrehder's Avatar
Thanks a bunch, ill have him check it
Old Dec 30, 2012 | 05:42 PM
johnrehder's Avatar
Default fixed
Yep the number 15 80 amp fuse was bad, got it running, thanks for the help!
Old Dec 30, 2012 | 06:28 PM
You're welcome. Glad to hear things are fixed.
Old Jan 27, 2017 | 09:47 PM
Bunches55's Avatar
duh today I did the same thing to my 1999 Honda accord! And yes no power now. Will this replacing the fuse work on my car as well?
Old Jan 27, 2017 | 10:01 PM
The Toecutter's Avatar
It should.
Old Jan 27, 2017 | 10:07 PM
For a 1999 Accord 4 cylinder, the battery fuse is under-hood Fuse No. 41 (100A). Remove the negative battery cable first before replacing this fuse to prevent sparks or accidentally touching ground and getting shocked. The large fuse requires a Phillips head screwdriver to remove.
If the battery fuse is blown and replaced and other components don't work, then also check under-hood fuses no. 47 (20A), no. 48 (20A), no. 49 (15A), and no. 50 (30A). -- These other fuses protect other circuits that also receive direct battery power.
Attached Thumbnails 92 accord battery hooked up backwards-underhood-fuse-box.jpg
Old Jan 27, 2017 | 10:52 PM
Bunches55's Avatar
Originally Posted by The Toecutter
It should.
sorry this is my first time on this site so forgive me if I'm repeating myself. Thank you first of all and would this pretty much apply to a 6 cyl as well?
Old Jan 27, 2017 | 11:02 PM
You're welcome. I just checked, and the fuse numbers appear the same for the 6 cylinder. Good luck.
