92 accord ex engine swap issues
my 92 accord has the f22a6 in it and started having multiple issues with it and decided to use my f22b2 out of a 95 accord ex I have for parts the block down is f22b2 everything else is the a6 now it seems to have a miss in it and when I shut it off it will leak oil on the driverside of the motor on the fire wall side it doesn't leak while the car is running and the miss it has is also partnered with it sounding as though its choking and my timing marks are correct according to the factory specs the top end has a new head gasket set with the intake gaskets and the exhaust gaskets are new and the valve cover gasket set complete with the sparkplug tube grommets any help or ideas will be appreciated this car is my baby had it for 8 years and my fiancé loves it too I have completely customized this car* I also torqued everything to spec that I could find if anyone has the torque specs for the rockar assembly I could use it
Sorry, I know it's not much help, but there's only so many things in that area that can leak. Also, are you sure is not power steering fluid? Just asking as the lines run thru there on the left side.
About the only things I can think of that would cause a leak in that area, would be the access plug for locking the rear balance shaft in place, or maybe the oil pressure switch. It's not the VTECH valve, as that's on the opposite end of the engine up top.
Levibyz
Jun 1, 2011 01:10 PM
mfskarphedin
Jun 6, 2010 09:33 PM
StatzFinest
Feb 10, 2008 11:32 AM
