92 Accord just dies, no dash lights.
Old Jan 14, 2011 | 06:22 PM
colorado_accord's Avatar
Default 92 Accord just dies, no dash lights.
Here's one, had an issue with it awhile back where it would just die for no real good reason, anytime, anywhere. The problem was the ignition switch, the electrical contact part of the switch mechanism, apparently the contacts were wore out (or maybe dirty) just enough to cause the car to shut off engine. The key symptom here is the dash lights go out, no battery light nothing. I guess this is a common issue with Accords but I had never heard of before. $60 for a new switch or you could probably pop the contacts apart and clean them and get but for a while....
Old Jan 15, 2011 | 06:21 PM
Kinda common with Hondas. I've heard that might be related to heavy keychains...?
Old Jan 20, 2011 | 07:54 PM
I figured I would add some info. Yes I have heard it could be caused by heavy key rings also, kinda have a hard time to believe that could wear out the electrical portion of the switch. I took the old switch apart after I replaced it, pretty easy to do so.. Looks to me that maybe just cleaning the contacts would fix the issue or at least it could not hurt to try. Pictures attached.
Attached Thumbnails 92 Accord just dies, no dash lights.-honda-pictures-004.jpg   92 Accord just dies, no dash lights.-honda-pictures-005.jpg
Jacob Steele
Oct 8, 2012 03:03 PM
Nicolai Hobbs
Jul 12, 2012 05:44 PM
Vettress
Jul 7, 2010 11:10 AM
marky4
Sep 7, 2006 01:25 AM
marky4
Sep 5, 2006 03:21 AM
