92 accord lx has no power to inside fuse box
Old Feb 25, 2013 | 06:01 PM
Recklesshonda's Avatar
Default 92 accord lx has no power to inside fuse box
I have no power to inside fuse box can't start the car or anything please help
Old Feb 25, 2013 | 06:18 PM
firefighter44's Avatar
Almost A Senior Member
Check the main fuse in fusebox under hood that goes to interior fuse panel to see if its blown
Old Feb 25, 2013 | 06:31 PM
We're is tht located
Old Feb 25, 2013 | 06:54 PM
Look in the fuse panel under the hood and checkout fuse #19, its a large 50A fuse. Should be labeled on the panel lid as Ignition switch (bat), option connector D.
I would generally check all the fuses just in case and if you find any blown fuses go ahead and replace them.
Let me know how that goes and we'll go from there
Old Feb 25, 2013 | 07:06 PM
Checked all the fuses there all good so what could it be
Old Feb 25, 2013 | 07:12 PM
What if anything was recently done to the car...replaced X, battery died, jump started a buddy....or I just walked outside and nothing worked?
Old Feb 25, 2013 | 07:23 PM
I was replacing the ignition switch the solder point on the switch
Touched metal and blew the 50amp I replaced it now still now power to the inside fuse box
Old Feb 25, 2013 | 08:00 PM
What is and isnt working inside the car?
Have you used a test light or multimeter to check for power on any of the interior fuses?
Old Feb 25, 2013 | 10:18 PM
Yes I checked all the interior fuses they all dnt have power
Old Feb 26, 2013 | 12:08 AM
I may be wrong here but i know on my 96 ex i dont get power to the interior fuse panel until the ignition is turned on. It sounds to me that perhaps yours is the same way and the trouble your having is the ignition switch that arched and blew your ign fuse is the culprit.
