92 Accord no blink on ECU codes.
Old Aug 1, 2019 | 04:17 PM
nitroplumber's Avatar
Default 92 Accord no blink on ECU codes.
Have 92 Accord 2.2. I have jumped the plug and turned key. check engine light comes on but no blinking and stays on. Have no start issue. fuel pump was bad replaced it (42 psi at rail). power at injectors, spark at plugs, resistance at injectors is good. Have replaced master relay, ECU, and injector resistor. rebuilt motor 20000 miles ago all was good. car in good shape trying to keep going for grandkid. any help would be apricated.
Old Aug 1, 2019 | 06:12 PM
plenum's Avatar
Find the starter in the car, do a light tap with a screw driver and a hammer. Right after you do this, have someone in the car try and start it (you have to do it right away after the tap). See if it starts, if it does, it could be the starter that is going bad.
Old Aug 2, 2019 | 05:31 AM
Along the same lines as the previous post, please provide us a better description of the no-start problem. Is the starter motor cranking the engine?
If the starter is cranking the engine, then you will have to narrow down if this is a fuel or spark issue.
Old Aug 2, 2019 | 08:15 AM
All the things that were replaced & checked (fuel pump, fuel pressure, spark) apply to the case where the starter motor DOES work, so I'll assume that.
How exactly did you check for spark?
Have you pulled out a spark plug to check if it's wet (flooded) or also whether there's any fuel at all (injectors not firing)?
Plenum's suggestion applies if the starter is NOT cranking the engine. And it works better if you hit the starter WHILE someone holds the key in the START position. (don't get caught in the belts in case it does start to crank)
Old Aug 2, 2019 | 12:11 PM
It cranks all day. on spark checked with probe had decent spark. it looks like I had no ground pulse. motor ran fine after fuel pump replacement. then just got to where it didn't want to start now won't. checked for codes, when I jumped plug and turned key the check eng. lite just comes on and doesn't blink. it stays on. Plugs were dry. does the light just staying on mean anything? when pull jumper fuel pump comes on with key turn and check eng lite comes on and goes out after prime.
Old Aug 2, 2019 | 05:36 PM
cranks fine. really feels like no ground pulse. as stated when checking codes the light just lights up. I can't find anything on that. was thinking maybe a ground issue. I have spark at plugs, 42 psi at rail, power to injectors. don't really have a good way to check for ground pulse just used a probe on + and next to terminal on plug with no action. not a big fan of just replacing stuff till get lucky. not sure if dizzy will show spark even if a sensor Is bad. not used to all them in dizzy. I'm more of a domestic guy over import but up till this point this one has been a good on for kids and grandkids now. got me ready to bang head against wall. haha
Old Aug 2, 2019 | 05:47 PM
Check engine light is supposed to come on for about 2 seconds when you first turn on the key (bulb check).
CEL turned on solid when you jumper the SCS connector, is supposed to mean there aren't any stored codes.
You say plugs were dry, but did you check after trying to start? If you take out the plugs right after trying you should be able so smell some fuel. So maybe the injectors aren't firing? Pressure at the rail is only part of it. The injectors need power full-time on one lead (same color wire for all 4), and the PCU switches the grounds (different colors) of the individual injectors. And maybe the injectors just don't work, but that's a big coincidence for all 4 of them...
Old Aug 3, 2019 | 11:49 AM
okay on light staying on with no codes. Yes checked plugs after cranking and dry.
OeZach
Dec 29, 2016 10:22 PM
The_OS
Jun 4, 2010 04:31 PM
hondabuyer
Sep 13, 2009 06:33 PM
Starfox
Jun 15, 2009 06:42 AM
shahk
Nov 12, 2006 02:27 PM
