Signal Lights do not blink
Old Nov 10, 2006 | 12:49 PM
shahk
Default Signal Lights do not blink
I have 2001 Accord LX. Left,Right and hazard signal lights do not work although all the bulbs are lit. What could be the problem and how do I solve it? Thanks in advance for the input.
Old Nov 10, 2006 | 01:40 PM
sir_nasty's Avatar
Default RE: Singal Lights do not blink
if they all just went out suddenly I'd guess you blew a fuse, look at your fuses under the dash and under the hood.... if that's not it you could have a bad combo switch... but most likely it's a fuse problem
Old Nov 10, 2006 | 10:57 PM
deserthonda's Avatar
Default RE: Signal Lights do not blink
underhood fuse box chk fuse # 49 15 amps,, under dash driver fuse box chk fuse # 10 7.5 amps
coild be a bad turn signal/hazard relay located in the undrdash driver fuse box
Old Nov 12, 2006 | 02:27 PM
YeuEmMaiMai's Avatar
take relay out and put a new one in. if problem goes away, you know what it was.... I doubt it is a switch....
Gangsta101
Feb 10, 2013 01:50 AM
trucknut88
Aug 29, 2011 08:39 AM
The_OS
Jun 4, 2010 04:31 PM
fusionstar
Jun 28, 2009 05:08 AM
Starfox
Jun 15, 2009 06:42 AM
