92 Accord Oxygen Sensor
Old Oct 20, 2011 | 08:29 PM
crw's Avatar
crw
Default 92 Accord Oxygen Sensor
I have a 92 Accord DX with 420,000 miles. It burned an exhaust valve so I removed the head and got it rebuilt. After finishing the head job the check engine light came on indicating the Oxygen sensor. I replaced it with a new one but still get the check engine light blinking one blink indicating a bad Oxygen sensor. The car runs good but my mileage has dropped from 32 mpg to 26 and I cant figure out why the check engine light still indicates a bad O2 sensor. Any idea on how to figure out what the problem is?
Thanks,
CRW
Old Oct 21, 2011 | 06:28 PM
Well, IF the sensor is known as good, then we need to move on to testing the wiring. Did the new one come with a plug or did you have to cut and splice.
There are a few other tests, the sensor (I know it is new but have to check everything). Fuel pressure, readings at the ecu.
Do you have a manual for this....the testing I'm speaking of starts ~6-24 of the service manaul I have.
Old Oct 21, 2011 | 11:20 PM
crw's Avatar
crw
The sensor I installed was the type you cut an splice the wires. I did check the connections with an ohm meter and the splice connections are working. I do have a Haynes manual and will do the checks they list tomorrow but there doesn't seem to be much there concerning this problem.
Old Oct 22, 2011 | 08:00 AM
Here is a start
Old Oct 22, 2011 | 08:11 AM
page 2
Old Oct 22, 2011 | 10:44 AM
If you reversed the sensor wires (usually white and black), you will get a code (guess how I know?). Any chance that happened. You should have instructions w/ universal sensor to align the wiring correctly.
Old Oct 23, 2011 | 05:42 PM
crw's Avatar
crw
No I have rechecked the wiring to the instructions and they are correct.
Old Oct 23, 2011 | 06:06 PM
Check the connector and wiring for faults by disconnecting at the ECU and confirming integrity of the sensor input and ground path. If these check OK, then ECU may have a circuit fault. We have seen a few of these recently for older 90-96 Accords.
You will need a shop manual to find the correct connector and wire at the ECU. Check Online Manuals post in DIY forum for a download manual if you don't have one.
Old Oct 23, 2011 | 09:23 PM
crw's Avatar
crw
I was just thinking there may be a problem with the ECU. I have also been having a problem with high idle around 2000 rpm after it warms up. I have replaced both the Idle Air Control valve and the Fast Idle Thermo Valve ( both used parts ) and nothing changed as far as the idle is concerned. If I unplug the Idle Air valve the rpms drop to about 700 rpms which is making me think something is signaling the valve to open up completely.
Old Oct 24, 2011 | 05:46 AM
Possible ECU could cause high idle, but I would first adjust base idle using the idle air bypass screw near TDC on throttle body entrance. W/ IACV electrically disconnected, adjust idle speed to about 600 +/- 50 rpm.
See some recent posts on adjusting the fast idle thermo valve. From memory, remove cover and turn valve CW to barely "snug". Check for the posts.
