92 accord wont start again
Old Apr 15, 2013 | 09:40 AM
tn6fshn's Avatar
Default 92 accord wont start again
My 92 accord won't run again. Every few weeks I park it and it won't start. Cranks ok, you can smell fuel, but won't start. Can't locate the filter to check, but since I smell fuel, filter should be good. Any help would be great.
Old Apr 15, 2013 | 11:51 AM
Suggest trying to start w/ starter fluid sprayed into air intake (5-10 second shot). If car still refuses to catch and run briefly, then a spark problem is likely. Check for battery voltage on blk/yel wire at the distributor electrical connector w/ keyswitch ON. If missing 12V, the ignition switch is likely the problem.
If car catches and runs briefly, then ignition is likely good and problem is low/no fuel delivery.
Old Apr 15, 2013 | 10:42 PM
hondadude's Avatar
Another common problem with that year honda is the main relay. Usually rears it's ugly head when interior temps are hot from sitting in the sun.
Old Apr 16, 2013 | 07:05 PM
Wow there is someone I haven't seen in some time Nice to see hondadude around.
gasface11
Jul 11, 2012 12:33 PM
bigb609
Dec 27, 2011 07:18 PM
MrGmo
Sep 28, 2007 01:40 AM
Jul 24, 2006 03:55 AM
Jun 2, 2006 02:24 AM
