92 EX 2dr windows + Rear defroster don't work.
Old Sep 7, 2011 | 05:43 PM
Jonah805's Avatar
Default 92 EX 2dr windows + Rear defroster don't work.
I had just fixed the rear defroster by replacing the fuse. Then it worked for about 30 seconds. The windows are intermittent, and the they work about 1/100 tries. They were working just as I fixed the rear defroster, then they BOTH quit at EXACTLY the same time!! I'm stumped. And I checked att of the fuses, and they're fine. Any suggestions?
Old Sep 7, 2011 | 06:03 PM
Which fuse did you replace, under hood or under dash. 15 and 19 under hood also tie to the windows and defroster, but so much more as well so I find it hard to believe either of those is bad but double check the screw connections to be sure.
From there I'd take one at a time. Windows, try switching the cooling fan relay with the power window relay, easy relay test assuming the cooling fans are working.
From there pull the switch from the door, I only have the 4 dr diagram-key on check for voltage on WHT/YEL, BLU/BLK, YEL/BLK, GRN/BLK -again this is for a four door, hence the four wires, your two door will be a bit different.
rockhoundrob
Oct 23, 2014 09:17 AM
rockhoundrob
Dec 12, 2013 01:35 PM
tchestman88
Aug 20, 2013 03:05 PM
rockhoundrob
Feb 6, 2013 06:30 PM
JetJock
Dec 1, 2008 08:42 PM
