92 EX Timing Belt Changed now have PROBLEM
Old Jan 19, 2009 | 07:00 PM
toddyfresh's Avatar
Default 92 EX Timing Belt Changed now have PROBLEM
I got a 92 accord ex. The oil seal blew so i had to change timin belt and put new seal in with retainer and he whole deal.. Anyways when Im done I rotated it by hand once everything still looked lined up. I start it and it starts up fine but now it idles at like 2000 and after started for a few minutes will lope idle from 1-2000 ... i checked timing and still lokks on. Anyone have any ideas?
Old Jan 19, 2009 | 09:41 PM
Default RE: 92 EX Timing Belt Changed now have PROBLEM
If you did the TB, I am guessing that you changed the water pump and drained the coolant. If you refilled the coolant without bleeding the air out of the system, air will cause the coolant temp. sensor to misread the temp.
Remove the radiator cap. There is a bleeder valve that takes a 12mm deep socket on the thermostat housing that you loosen, air will spit out with coolant. Close it when a steady stream of coolant comes out. Top off the radiator, put the cap back on.
I would also pull the 7.5 amp radio/backup fuse in the engine bay fuse box for a minute. That will clear the ECU.
kc68
Jun 16, 2016 05:17 PM
93Accord2.2
Nov 6, 2013 11:53 PM
dis360
Sep 12, 2013 04:08 PM
Protna
Aug 14, 2011 02:58 PM
traceme
Nov 5, 2009 08:36 AM
