92 honda accord ex overheating
Old Oct 24, 2006 | 05:26 PM
92HARLEMHONDA
Default 92 honda accord ex overheating
It seems i'm having a bit of trouble here. As i said i have a 92 honda accord ex 4dr sedan and having problems with over heating. I changed the radiator , thermostat twice , temp sensor , temp switch and still i seem to be having problems. the fans come on. and the gauge lowers but it always rises back up. if anyoneout the can help a fellow hondaer out please do.. ty
Old Oct 24, 2006 | 07:17 PM
Chiovnidca's Avatar
Default RE: 92 honda accord ex overheating
Have you bled the air out of the system?
Old Oct 24, 2006 | 07:45 PM
sir_nasty's Avatar
how high does it go? have you ever run it into the red? Have you checked your oil to make sure that there isn't any Anti-Freeze that leaked into it?
Old Oct 25, 2006 | 04:49 AM
YeuEmMaiMai's Avatar
is the water pump functioning? If so they it could be one of a few things
1. bad rad cap releasing coolant due to broken pressure releif valve
2. exhaust leak into coolant because of a head gasket
3. blockage in the block somewhere
Old Oct 25, 2006 | 12:15 PM
deserthonda's Avatar
you need to make sure that engine is actually overheating and not just a bad gauge,,,,,,,
did you install a Honda T-stat??..how quick does the temp needle rises up ??
Old Nov 7, 2006 | 08:39 AM
92HARLEMHONDA
Ok i'm back after a few ajustments. I just changed the water pump and no i didnt use a honda t-stat. (<----autozone. would that make a diff?) and now i'm still having the same prob. except it only rises to the N above the D4 then it drops back down to the D4. could this be the head gasket?
Old Nov 7, 2006 | 05:40 PM
ArcticHonda's Avatar
Dude, the 1st thing you need to do is go get a HONDA thermostat. Go to the dealer and get one. Do not use an after market stat. I cant take credit for the below picture (originally from Hondamatic) but it shows why there is a need for a Honda stat. Also, replace the gasket with the new one that comes with your Honda stat. Try this and then let us know.
[IMG]local://upfiles/6435/F59786D38BF7411F9A3D5E0B233CA5CF.jpg[/IMG]
Old Nov 7, 2006 | 06:07 PM
sir_nasty's Avatar
if it's rising for a ways then dropping back down it sounds like the t-stat. The engine is heating up and it's not opening when it's supposed to then it kicks over and allows the fluid to flow through and the temp goes down..... either that or you have a bad guage... but it sounds identical to what my 94 civic did when the t-stat went bad
Old Nov 7, 2006 | 08:34 PM
forgwet the N above the D4 stuff..............you got a temp gauge,,,,,,,,where does the needle rise to on the temp gauge ...?? 1/2?? 5/8 ?? 3/4 ?? 7/8 ??
Old Nov 7, 2006 | 08:47 PM
sir_nasty's Avatar
*ROFL* I swear desert sometimes just based on your posts I can tell it's been "one of those days".... you crack me up man I truly enjoy reading your posts
