92 LX 97k need help
Old Jan 13, 2012 | 09:34 PM
A.M.Havoc's Avatar
Exclamation 92 LX 97k need help
What's up forums, I'm new to the site and I have a 92 Accord LX with 97k. I've had this car for about 4 months and slowly I have been noticing problems. I know my motor mounts are shot and one of my exhaust mounts broke of from rust and made a quarter size hole in it. It's right after the down pipe and befor the cat converter also tranny seems to be slipping i was told to change my fluid and replace filter. I have been wanting to make some miner upgrades but not shore were I should start. If any one has some incite it would be most helpful
Old Jan 13, 2012 | 09:45 PM
Check each motor mount to see which ones are causing movement. Try grabbing the valve cover to push/pull on the engine and see which mounts have excess movement.
Do a drain and refill on the transmission. Do not have the transmission flushed. There is no filter to change. Use the ATF recommended in your honda owner's manual. Honda automatic transmissions are picky about their transmission fluid.
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
gottabekin
Jul 13, 2010 09:16 PM
mamtsberg
Mar 17, 2010 09:15 PM
