92 LX wont start!!
Old Jul 16, 2008 | 08:34 PM
r3b3lth3ory
Default 92 LX wont start!!
hey i have a 92 accord lx like the title says and it wont start. it wouldnt start at random times before but if i tried it then waited a minute it would turn on. now it just stopped wanting to start. it is getting fuel it seems like and is turning over its just not getting a spark to fire at least thats what it seems like. i replaced the distributor cap, rotor, and spark plugs and it didnt really change anything. could it be my actual distributor or what else would make it do that?
Old Jul 16, 2008 | 10:38 PM
Default RE: 92 LX wont start!!
You need to test if the no-start is from lack of spark or lack of fuel. Hook a spark plug wire to one of the old plugs. Ground the threads to the engine block and have someone try to start the car. You should see a bright blue/white spark.
As for fuel, try to listen for the fuel pump when you initially turn key to the II position. The pump is only on for a couple of seconds and had a faint whirling/buzzing sound. Have an assistant turn the key to II and listen at the gas cap.
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
