93 Accord Brackets & Stays Under the Hood
Old Nov 1, 2024 | 08:38 PM
yoop's Avatar
Default 93 Accord Brackets & Stays Under the Hood
I was brought in 1/2 way through a major overhaul on a 93 Accord EX. I'm almost finished, but I've got 3 brackets/stays which I don't know where they connect. Does anyone know where these brackets go? I've looked at every parts diagram on Hondapartsnow and combed through the Haynes manual.
The 1st is a wire bracket just above the starter. The 2nd is a stay for the hydraulic line going to the clutch slave cylinder. The 3rd is on the driver's side, near the firewall around the power steering hose. It's just below the master cylinder Anyone have a 93 Accord EX with a manual transmission that can post some pictures showing where these are anchored?
Thanks in advance.
Sensor wire over the starter
Stay for hydraulic line to clutch slave cylinder
Hose from power steering pump in front of and below master cylinder
nce.
Old Nov 3, 2024 | 07:59 PM
kris_loehr's Avatar
All of those look like they go where the bolts are near them. You should be able to see an indication of where they were from a lack corrosion shaped like the bracket at that point.
Leoniel1245
Apr 25, 2015 09:50 AM
brassbanana
Feb 10, 2014 02:44 PM
nascar2806
Jul 3, 2011 06:49 PM
tradosaurus
Jun 23, 2011 07:07 AM
Antarctica
May 17, 2009 09:36 PM
