93 accord coolant leak (water pump?)
Old Feb 1, 2010 | 09:42 AM
demetrius's Avatar
Default 93 accord coolant leak (water pump?)
my 93 accord has a coolant leak which is coming from a small nipple, driver side, near timing cover around the same elevation as the oil filter. the coolant is definitely leaking for the nipple/hole, if i covered the hole with my finger the leak stopped, when i uncovered it coolant leaks. the nipple is in about the 2 o'clock position (12 being up). i think it is the water pump weep hole but i am unsure. if anyone has a picture or good description of the water pump weep hole or any related info. your help will be appreciated. the nipple is very small and raised (like a boss) a very little.
Old Feb 1, 2010 | 09:50 AM
g22cd5's Avatar
Supper Moderator
Read this and see if it helps.
http://www.honda-tech.com/showthread.php?t=2411527
and this one too.
http://www.superhonda.com/forum/f13/...r-leak-351407/
But it sounds like to mee to your watter pump is going bad....Look into changing it.
The 2nd link has a good pic and everything. Hope this helps.
-Ryan
Old Feb 1, 2010 | 10:52 AM
demetrius's Avatar
thanks for your help but the picture was not available so i could not see it.
Old Feb 1, 2010 | 11:32 AM
g22cd5's Avatar
Supper Moderator
That's the pic I was talkin about. I posted it since you couldn’t view it.
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
erikhans
Sep 11, 2013 06:48 PM
PinkFloridaFlamingos
Nov 27, 2011 06:02 AM
wedtm
Mar 26, 2008 10:10 PM
joe592
May 25, 2006 03:35 AM
