93 accord h22 swap problems
Old Mar 30, 2011 | 09:28 PM
jessecolter's Avatar
Default 93 accord h22 swap problems
I know the wiring has to be redone when you do this.. when I picked it up they had forgotten the o2 sensor and it was running like crap, so I wired it (had to be extended as the performance exhaust has the hole on the downpipe) and took it back.
They cleaned off the spark plugs and told me the wiring needed to be the right gauge. I drove it like that to the wire store and wired it again.
All the while and still running like crap, not getting the right fuel/air, smells terrible, shakes at idle, no power at all. Do I need to clean the plugs again? Any ideas on how I can trace the issue? Thanks.
Old Mar 30, 2011 | 10:47 PM
What ECU/TCU (not sure if you have an AT or MT) are you using? Is the H22 a vtec engine?
Is the check engine light turning on while driving?
Old Mar 30, 2011 | 11:07 PM
It is an automatic as it was before the swap, yes it is an h22a vtec. The check engine light is on and the D flashes. I believe the ecu from the new motor was used, I am going to go see if I can get a reading on which one it is.
Old Mar 30, 2011 | 11:16 PM
I couldn't quite get the ECU out but it looks like the original one... going to have to see whats up with that when they open tomorrow.
Old Mar 30, 2011 | 11:34 PM
Something is up with the engine computer (check engine light on) and the transmission computer (D light flashing).
The H22 ECU and TCU should be used in this swap. They should check for error codes to see what the computers are detecting.
Old Mar 31, 2011 | 12:50 AM
Yeah it looks to me like the original control units are still in, under the passenger kick plate right? Are the right ones going to fit or is it going to be a mess? I'll be going to the shop to see whats up tomorrow, thanks for your help.
Old Mar 31, 2011 | 01:44 AM
I never read anything about the ECU not fitting before. The H22 swap has been done a lot. Search the web to find out what needs to be done.
If you copy and paste the link below, you can get a H22 swap guide. Those files are at the bottom of the web page.
spoonertuner.com/manuals
Old Mar 31, 2011 | 10:27 PM
Default h22 ecu
I got the ecu that came with this motor and yes it fits, it says F90 on it. I didn't get one for the trans so I left that ecu the same. Now the car is actually worse, still engine light, I idled around the parking lot, pressing the gas gave it less throttle. Not sure whats going on.
Old Mar 31, 2011 | 11:17 PM
Default maybe this explains
plus I don't know what's up with either of these loose ends, maybe this explains
Attached Thumbnails 93 accord h22 swap problems-sensor1.jpg   93 accord h22 swap problems-sensor2.jpg
Old Mar 31, 2011 | 11:57 PM
In the second picture, there is a vacuum hose #16 that is not plugged in and the map sensor is not plugged in.
The first picture looks like something with the vtec is not connected.
What you should do is check for error codes. The procedure should be the same as for your 93 accord, so read the DIY writeup called how to get cel codes.
