93 battery cables
Old Oct 19, 2012 | 11:42 AM
sirtwist2's Avatar
Default 93 battery cables
Hi,
As part of a long list of things to fix and/or replace on my car, and also to deal with some electrical problems, I want to change the battery and cables before winter. The terminals constantly get corroded and the negative cable is missing the cover on the lower half.
My questions concerns the cables. The negative cable is split into two and the positive cable is split into three, including a ground. The cables they keep trying to give me at the local parts stores aren't the right ones. I found some OEM cables online, but the two together are $84.
Is there a cheaper place to get the cables? Do I really need to have a ground on the positive cable?
Thanks for any help!
Old Oct 19, 2012 | 12:25 PM
I saw some on ebay that might be slightly cheaper (OEM). These prices are not too bad.
Yes, you need the ground jumper to avoid problems. Ground path problems can be nasty.
Old Oct 19, 2012 | 12:28 PM
Hey Gary, good to see you again..
Old Oct 20, 2012 | 01:46 PM
sirtwist2's Avatar
Can you get non-OEM cables anywhere that are the correct ones?
I don't recall seeing grounds on other cars I've had, is it normal to have a ground on the battery cable?
Thanks!
Old Oct 20, 2012 | 03:58 PM
Grounds are different for different brands/models. It is not uncommon to have a ground directly from battery to body. This provides a return path for all elements that are grounded to the body, rather than through body to engine, to battery.
Old Oct 20, 2012 | 07:58 PM
sirtwist2's Avatar
Ok, thanks for responses. I think I'm going to bite the bullet and go with the parts from The Honda Parts Store website.
Thanks again!
benjamindavidbiggs
Dec 10, 2008 06:58 PM
thunder_x
Mar 24, 2008 04:48 PM
DA KID RYU
Dec 31, 2007 06:15 AM
steviebix
Aug 14, 2007 11:07 AM
JFK
Mar 31, 2006 05:53 AM
