93 honda accord ecm wont accsess codes
Old Apr 11, 2011 | 07:48 AM
chevmechanic's Avatar
Default 93 honda accord ecm wont accsess codes
check engine light is on and i cant get to pass smog because the ecm wont spit out the codes. found the 2 wire connecter behind passenger kick panel but light wont flash. i am thinking that the ecm might be bad any suggestions?
Old Apr 11, 2011 | 12:26 PM
Three possibilities;
Make sure you jumped the correct 2-wire pin (blu connector) usually connected to a dummy holder. Pinch and release to access.
Reset ECU by pulling BackUp fuse (7.5A) in underhood fuse box for 20 secs. Drive and see if codes return, then recheck for codes.
Pull back carpet on passenger foot area to expose ECU and TCU housing. There are windows in the housing that alow you to see LED's on the ECU when they flash. Turn keyswitch to On (no need to short service check connector) and read the red LED flashes. The two windows are about midway, upper face of the housing, LH window is ECU and RH window is TCU.
Old Apr 12, 2011 | 08:52 AM
Default 93 accord wont accsess ecu codes
thanks for the reply. i will try that and see what i can find out.
will repost my results.
Old Apr 17, 2011 | 08:21 PM
Ok i pulled back the carpet but no led lights. Took ecm out of housing and no led flashing what is going on with this car?
Old Apr 17, 2011 | 09:21 PM
Was keyswitch On when you were checking? If yes, then ecm may indeed be bad. Make sure power is getting to ecm; check BackUp fuse in underhood fuse box.
Old Apr 18, 2011 | 09:02 AM
yes key was on but i mean to say there are no leds in the windows period.just metal its like they forgot to install the led light bulbs.
Old Apr 18, 2011 | 06:22 PM
The leds are not in the window but on a circuit board perhaps 1" below the window. When led flashes you can see it through the window. If you saw nothing then it wasn't flashing.
Old Apr 19, 2011 | 08:49 AM
ok i took the panels off to look at the circuit board and no led bulbs or flashing of lights. could they be after market?
Old Apr 19, 2011 | 08:53 AM
here is a little more info when the check engine light comes on if you turn off the car and restart the light goes away for about a mile and comes back on. and if your turn the car off again it goes off and comes back on after a mile. now the smog place says it has high hc's at idle and at 1500 rpm's.
Old Apr 19, 2011 | 06:26 PM
Did you reset the ECU and try to extract codes by shorting service check connector when the code returns?
Don't know why there are no LED's. I thought all the 90-93's had them, but maybe they discontinued the LED's at some point. They are redundant to the primary code extraction method.
