93 Will Not Even Crank.
Old Feb 26, 2007 | 07:58 PM
mgreisamer
Default 93 Will Not Even Crank.
I have a 1993 Accord LX. I tried to start it the other day and all the lights came but the car would not start. It does not crank, or even click really. The only thing I get is one click right as I turn the key. The battery is fine and I have checked all of the fuses. I could use any ideas as to what could be wrong. Thanks.
Old Feb 26, 2007 | 10:32 PM
Default RE: 93 Will Not Even Crank.
Does the Check Engine Light (CEL) come on when you turn the keyswitch to ON? Do you get a click from the engine compartment each time you turn the keyswitch? If yes, the problem is likely worn starter solenoid contacts. Search recent posts on starter repair for tips on repair.
Make sure battery connections are clean and securely attached to battery.
Old Feb 27, 2007 | 01:31 AM
deserthonda's Avatar
how do you know that battery is fine?? did you do a load test?? new battery ?? if you are sure battery is ok, than do as tex honda suggested make sure cable are clean and tight,,
have someone try starting the car, get a big screwdriver and bang on the starter while they crank,, if it fires up you got internal starter issues
Old Feb 27, 2007 | 05:36 PM
One click at the starter usually means that the starter solenoid isn't making a good contact to turn the starter motor. Replace the contacts and the solenoid for ~$25. It was a very simple job to do.
I got my parts from : http://stores.ebay.com/Alternator-St...enerator-Parts
You might have to email him for your specific model. He has a link on his listings to show how to install the contacts too.
Check the battery and connections as suggested, but I'll bet that the solenoid/contacts are bad.
Old Feb 27, 2007 | 08:24 PM
hondadude's Avatar
Here is a pic of the new starter contacts in my Yota 'ND' starter, very easy to replace and less than $15 for the set of contacts
Steven Perron
Jul 2, 2012 01:26 PM
HondaNewb
Mar 13, 2012 08:14 PM
pab59y
Sep 13, 2011 06:33 PM
Jeffrimerman
Mar 19, 2010 07:11 AM
tibbo
Jul 25, 2006 08:00 PM
