94-97 A/C not cool enough
Old May 1, 2005 | 10:37 AM
Evlampius's Avatar
Default 94-97 A/C not cool enough
Ok pplz,
Some of you 94-97 accord owners must experience the problem with A/C not cooling enough
I thought of you...the summer gets here - so before you go and spend $$$ on A/C recharge and/or temperature cable replacement ( which you need ) heres a little trick to make it work...
....ummmm anyone interested?
Old May 3, 2005 | 02:16 AM
Evlampius's Avatar
Default RE: 94-97 A/C not cool enough
soooo , no one is interested??....oh my all of your A/C are working great??
Ok , i'm not gonna tell you then....[sm=idontcare.gif]
Old May 3, 2005 | 05:18 AM
Well at least when ever their A/C doesnt work any longer, they will come and look you up for that answer.
ORIGINAL: Evlampius
Old May 3, 2005 | 09:37 AM
jayhova804's Avatar
Im interested my air works but i defiantly think it could be a lil cooler
Old May 3, 2005 | 11:06 AM
Evlampius's Avatar
hehe - Wheel broker you're right!
Jayhova - what kind of car model do you have what year.
have you serviced the A/C , added R134a?
Old May 3, 2005 | 12:10 PM
jayhova804's Avatar
94 ex and i have not had it serviced
Old May 3, 2005 | 12:22 PM
Evlampius's Avatar
when you have moisture on the windows and you turn the AC on does the moisture disaappear? meaning the AC is working
Old May 3, 2005 | 12:37 PM
Evlampius's Avatar
So - all 94-97 accords are affected with the temperature control cable problem
the cable just doesnt shut the coolant valve till the end . Honda recommend replacing the cable but heres what you can do in order to get cold air.
turn the temp. dial all the way to the cold , no reach the heat control valve with your hand - and push a little bit toward the front of the car. It will go may be 1/4 of an inch or little less but it will completely shut the valve - and you'll be getting cold air shortly.
now to locate the valve
stand on the passenger side of the hood, reach your hand below the air intake and its kinda on the bottom and the cruise control cable is on the way. theres a big hose that connects to the heater core - theres a white plastic piece with cable attached to it. there is a small space just enough for your hand to reach the bottom. If you having trouble locating it i'll make you some pictures
attention: do not close the valve with force - it will move toward the front of the car about 1-1.5 cm easily without much presssure and will stop - its closed.
it is not a fix - if you turn the temp control dial to hot and back to cold - the valve will not shut completely again but just pushing it with your hand is a little trick to make it work.
in order to fix this problem you have to replace the cable.
enjoy
Old May 3, 2005 | 02:13 PM
jayhova804's Avatar
i think icould find it but pics would really help
Old May 4, 2005 | 04:05 PM
Evlampius's Avatar
here you go bud..
[IMG]local://upfiles/439/248353A7FC6E4D7B8C9485A1897EC96B.jpg[/IMG]
[IMG]local://upfiles/439/DF456F3EC3EA42768DB6E1D3B45EA39D.jpg[/IMG]
remember dont go crazy - about 1 cm to close thats it
