94-97 A/C not cool enough
Old May 5, 2005 | 01:09 AM
jayhova804's Avatar
Default RE: 94-97 A/C not cool enough
looks like a good thing to try in the morning while the car heats up thanks bro
Old May 5, 2005 | 01:40 AM
Evlampius's Avatar
dont forget to turn the dial all the way to the cold - tell me how it works
Old Dec 4, 2005 | 03:29 PM
overlordjd's Avatar
I'm new to the forum but I've been trying to figure this issue out sine I've had the car. I just left it alone after a while cause I wasn't driving the car. I've had it serviced and kept asking everyone I knew that had an accord with the year of 94-97 if they had the same problem with it not being cold enough. Thanks for the tip in finally resolving this issue.
Old Dec 4, 2005 | 06:34 PM
deserthonda's Avatar
LOL LOL .....don/t mean to insult you my friend but that is your trick????? if the cable is adjusted properly you don't have to do that ...there are 2 adjustments on the cable 1 under the hood at heater valve, the other under the dash on pass side where the cable controls the doors ...
unhook cable from heater valve, unhook cable from under dash, turn heater **** al the way to cold, pull on the lever where the cable attaches under the dash so it is all the way close, hook the cable , go at heater valve pull the little lever on the valve so it is all the way close. hook the cable ,,,,,If adjusted properly when u are all the way on hot or cold the cable will open or close fully,, no need to go under hood and pull it manually
Old Dec 7, 2005 | 02:07 PM
overlordjd's Avatar
Can't wait for summer to come around so I can enjoy this.
Thanks again guys
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
MROOKIAN
Jul 26, 2010 04:08 PM
topgd
Jul 8, 2008 01:28 PM
Markus26
Aug 20, 2006 05:05 PM
flomasta
May 2, 2006 11:08 PM
