94 accord
Old Jun 25, 2012 | 07:42 PM
Ajtayosr's Avatar
Default 94 accord
The ac compressor does not get power , what can it be, where could the problem be ...om not familiar with the system at all so where should I start
Old Jun 25, 2012 | 08:37 PM
The first thing I would do is to start the car and turn on the a/c. Do both fans on the radiator turn on?
For some preliminary testing, start at the pressure switch. It is on one of the a/c metal hoses under the battery tray.
Unplug that pressure switch. You can jump the electrical connector with a piece of wire, then start the car and turn on the a/c. If the compressor turns on, turn off your car immediately. That would mean that you have low pressure and have a leak in your a/c system. Or a faulty pressure switch.
If the a/c compressor clutch does not engage, we can give you some other tests to try.
Old Jun 25, 2012 | 08:42 PM
my1st.honda93's Avatar
when you say it does not get any power?are you saying it doesn't turn on?or it doesn't get cold?or turns on but does not get cold?which 1 is it?
