94 accord air stinks
Old Apr 23, 2008 | 01:07 PM
davenam
Default 94 accord air stinks
The A/C in my 94 accord smells like mildew. Any ideas how to get rid of the smell?
Thanks!
Old Apr 23, 2008 | 11:11 PM
19Accord97
Default RE: 94 accord air stinks
I am assuming you havent had it for very long?
I had that issue a few times. Most people spray Lysol into (I forget where, sorry ).
What I do is crank the heat to full blast for at least 5-10 minutes to try and kill/push out all the bacteria in there when I am on my way home and shut it off just after the "heat treatment". Also, when you are using your A/C it is a good idea to turn off the A/C but leave the air going to push out all the moist cold air. This will prevent mold and mildew from forming.
Old Apr 23, 2008 | 11:16 PM
also not a bad idea to replace the cabin air filter
Old Apr 23, 2008 | 11:38 PM
19Accord97
I dont think our gen has one.
Old Apr 24, 2008 | 11:45 AM
deserthonda's Avatar
a couple of things
# 1 forget about the cabin air filter , accord did not have 1 till 1998
# 2 if you want to fix it properly and lasting,, you need to remove the evaporator, replace both foam insulators, clean the evap cases with soap and water, clean the evap from any debris, spary it with some ( fridgy-fresh, Lysol etc etc ) put it all back together.. now to do this you need to evacuate and then recharge the a/c system,
if you do it any other ways,it will not last long at all, smell will come back in a short while
Old May 12, 2008 | 01:09 AM
Hobbin's Avatar
Hey speaking of replacing evaporators and recharging AC.....
I have no cold air.
I live in the pacific NW, it's always rainy and wet, and my windows are ALWAYS fogged.
Aaand plus it kinda smells in there too.
Will these replacements fix the symptoms?
ORIGINAL: deserthonda
shoot22
Feb 2, 2019 05:40 AM
meazz1
Dec 15, 2017 07:35 PM
00AccordLX5spd
Feb 17, 2008 03:14 PM
jeremiah6120
Apr 16, 2006 03:32 AM
