94 accord batterie drainage
Old Oct 30, 2009 | 09:28 PM
dan25
Question 94 accord batterie drainage
hi to all
i have a question concerning drainage of my batterie. batterie has been tested its a1 but if i go in a store for 30min and come back out the batterie is dead not even strong enough to light the dash lights but if i take the possitive post off the batterie everytime i stop the car and put it back on everytime i go to leave it will start a1 the batterie won't keep its charge so i know there is something staying on but something big that drains the batterie very fast so i was wondering if someone already had this problem or will know what is causing this or how could i test to find out what is causing this??
i would appreciate the help alot. thanx to all.
Old Oct 31, 2009 | 12:24 AM
Exclamation
Take the car to Advance or AutoZone and have them do a systems check on the Alt,Starter and the Battery...Let us know
Old Nov 1, 2009 | 06:06 PM
dan25
yeah i followed a few tips from google and found my problem. it was the defrost. i was wondering if the defrost had a relay switch if yes where is it located?? or just that big fuse under the hood?? and also i was wondering where is gas pump relay located??
Old Nov 1, 2009 | 08:30 PM
Defrost relay is in the cabin fuse box on the driver's side.
The main fuel relay is under the driver's dash. See http://techautorepairs.com/mainrelaydefine.html
Old Nov 8, 2009 | 11:17 AM
Excellant link for the Troops you gave..Thank's PA
chuyiito20
Nov 28, 2012 05:12 PM
GN517
Aug 21, 2009 04:49 PM
Hondaz
May 4, 2009 07:48 AM
