94 accord crank but no start issue help
Whats up guys im new and i have a 94 accord f22b vtec motor and im having trouble getting it started i checked the spark plugs and im gettin spark and i checked the fuel pump and im gettin gas .. all fuses are good and i replaced the 100a main fuse .. what else could b my problem
How did you check fuel?
Can you verify the fuel injectors are firing?
If you spray starting fluid into the throttle, and it sputters & fires for a second, then you're missing fuel. Possibly the injectors aren't firing.
After trying, pull a spark plug. Excessively wet with fuel? The fuel won't fire if it's too rich. If so, check the vacuum line on the FPR. If there's fuel in that line, your FPR is ruptured.
9foaccord
Nov 22, 2010 08:46 PM
