94 accord dome light always on.
Old Dec 16, 2010 | 01:02 PM
fusionstar's Avatar
Default 94 accord dome light always on.
So I was driving home from the supermarket and the dome light, all 4 door lights, and the trunk light turned on. I thought that was weird, So I pulled the 7.5amp Interior Light fuse then I noticed my from left turn signal/running light was dead. Inserted the fuse back in and it works again. I am at a lost. Mechanical problems are one thing. Electrical, I don't even know where to start.
Old Dec 16, 2010 | 01:46 PM
Check the door switches first. Open each door and press the door switch, it has a rubber grommet covering it. If one of them is bad, just pull the rubber grommet off, usually one screw holds it on, on most Hondas. Then unplug electrical connector and replace.
Old Dec 16, 2010 | 06:59 PM
Tell us which lights turned on. I wasn't sure from your description if the indicator lights on the cluster turned on, or the actual lights on the door turned on.
Anyway, you may need a volt meter to do some testing. They cost <$20, and can help out when you run into electrical problems. Also, download the 94 shop manual from the online manuals thread in the DIY section. Then you can see the locations of certain items that we describe to you.
Old Dec 16, 2010 | 09:15 PM
fusionstar's Avatar
The lights on the doors itself is on. As well as the dome light and trunk light. The door indicator light on the cluster is not on. So essentially. Its as if a door is open. But they are closed.
The left turn light died when I pulled the Interior Light fuse so my battery wouldn't die.
I will try redbull-1's suggestions and see if its just a switch.
I do have a volt meter but only know how to check for continuity and voltage. I have the manual for my car and took a quick look with no luck.
Thanks
Old Dec 16, 2010 | 10:04 PM
fusionstar's Avatar
Thanks
Turns out the ICU I replaced a few months ago was bad. Got a replacement and all is well again. Thanks guys.
Old Dec 17, 2010 | 01:41 AM
Glad you figured it out. Thanks for posting the fix.
jkalathas
Jan 5, 2022 06:13 PM
circa_1981
Dec 16, 2013 10:08 AM
bdrumm
Oct 30, 2012 10:46 AM
milescwright
May 23, 2010 09:46 AM
