94 accord idles low then dies
Old Sep 25, 2011 | 12:39 PM
Zombsta's Avatar
no i was just about to go out and start working on everything and I bought it from a dealer so I didnt get anything
Old Sep 25, 2011 | 10:19 PM
Zombsta's Avatar
I cleaned out the tb today, behind the plate it was dirty as could be. On the distributor cap the center little button thing not sure what its called but reminded me of flint stuck when I first pushed it in. also the spark wire connecting to the distrubutor cap was pulled out some not sure why. after all this the cel still came on and I still had alittle trouble with idling but i havent got to drive it to much today.
Old Sep 26, 2011 | 06:30 PM
CEL can take a couple driving cycles before it clears, depending on what the error was. Cleaning up (or replacing) the distributor cap is good.
Old Sep 28, 2011 | 09:13 PM
Zombsta's Avatar
i did everything mentioned before, it drove fine for the week but today it started sputtering again at 2750 rpm almost like it was hitting rev limit. not sure whats going on????
Old Sep 29, 2011 | 03:48 AM
johnny_1203's Avatar
Save yourself some cash and pull you cap off and with a flathead scape off the carbon build up on the contacts. Replace your wires, clean battery trems, and if its a starter issue try taking the back end of your jack handle and tap the stater a few times.
I had a issue like this about a year ago and couldnt figure out the issue either. Took the head off, replaced timing belt, got another ECU from junk yard, all failed. I ened up hae a mech (20 years exp) look at it he was baffled as well, Anyhow it ended up just bein a dirty injector.
Nicolai Hobbs
Jul 12, 2012 05:44 PM
POS-Accord92
Nov 7, 2011 06:50 PM
Accord Pete
Jan 31, 2010 02:50 PM
illusivehour
Dec 25, 2009 10:14 PM
achilles600
Jun 18, 2009 10:13 AM
