94 Accord LX no start
Old Dec 15, 2009 | 02:27 PM
jesselap's Avatar
Default 94 Accord LX no start
HI Guys,
I have a 94 Accord LX coupe that stalled at a stop light, and will not start now. I can hear the fuel pump turn on and run, but it just cranks, no start. Any sugestions in narrowing down the problem would be appreciated, as the local mechanic wants $150 just to look at it. Thanks
Old Dec 15, 2009 | 02:57 PM
If you have a timing light, hook it up to a spark plug wire and try to start the car. The light should flash when the engine is cranking.
Old Dec 15, 2009 | 07:38 PM
Dshow's Avatar
Check for spark mentioned above, check fuel pressure, and then check compression.
Old Dec 16, 2009 | 12:57 AM
kris_loehr's Avatar
You need fuel, spark and compression to run. You can put a spark plug in one of the wires and with the metal part of the plug grounded and check for spark. Take a plug out and put a little gas in and reassemble and see if it tries to start or spay some gas into the throttle body with it held open. Check and see if the cam is turning and last a compression test if you have fuel, spark and the cam is turning.
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
gasface11
Jul 11, 2012 12:33 PM
brickballer
Apr 18, 2008 04:25 PM
