'94 accord shift rpm?
Old Jan 13, 2010 | 12:32 PM
Buckwild331's Avatar
Default '94 accord shift rpm?
Just bought a 1994 accord 2.2 vtec automatic. The transmission went out so I replaced it with a used one. Everything seems to be working fine, just had one question. When I'm full throttle it shifts at 4500 rpm. Is that normal? I hear the vtec kick in at about 4100-4200 then shifts at 4500-4600. I figured i'd get more than 300 rpms of vtec. I'm new to the import world so any help would be great, thanks.
Old Jan 13, 2010 | 02:07 PM
Maybe the adjustment on the transmission control cable - that's the cable from the throttle-body down to the trans.
The control lever on the trans should begin to move IMMEDIATELY when the throttle begins to open. If that cable's too loose, the tranny will think you're not at WOT.
Old Jan 14, 2010 | 08:26 AM
Default Thanks
I'll take a look at this when I get to work. Will this problem cause my overdrive light around the D4 indicater to flash till the check engine light comes on?
Old Jan 14, 2010 | 10:09 AM
The flashing D-4 lamp is the tranny's version of a check-engine light. Jumper the SCS connector like you're gonna read the flashing CEL code. But the D-4 lamp will flash instead (or in addition to) the CEL.
rydnlow1120
11
Nov 11, 2015 05:29 PM
Airhead
Jul 21, 2014 04:55 PM
thunder_x
Oct 24, 2007 10:26 AM
Norway
Apr 15, 2006 03:33 PM
Trens
Aug 3, 2005 03:22 PM
