94 Accord stalled while driving,flashing D4 light
Old Jan 14, 2013 | 07:22 PM
mygirlsaccord's Avatar
Default 94 Accord stalled while driving,flashing D4 light
I've hade a 1994 accord ex about 4 years , it recently, before shifting to the next gear sputters, then kicks in to gear. Two days ago, while driving the car it stalled out. It cranked but would not start back up. I noticed the D4 light on the dash blinking continuously when the key was on. Ended up towing it! I found this website an proceeded with doing research. Here's what I come up with.
PAhonda
2005 Acura TSX
The D4 light blinking means the transmission computer is detecting a problem. Find out the problem by getting the DTC code.
To check the codes follow the instructions on this site:
http://www.dhost.info/accordinfo/howto/cel.html
Use a thin paperclip to short the connector. Count the D4 light to get the Tranny code(s). Count the Check Engine Light to get the Engine Codes.
__________________
2005 Acura TSX MT
I've done this an my CEL stays on(dose not blink), the D4 light flashes are as follows: 1 short, 8 short, 1 long, 3 short, 1 long, 4 short. I think it is(if I read right) codes:
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve.
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor.
4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor.
Thanks a ton to PAhonda for his past posts! If anyone can further help me out by telling me if this is correct or what it could be, it would much appreciated. Hope im wrong, this thing may see the scrapyard soon because I don't have the funds nor the tools combat this issue. Thanks Much!
Old Jan 14, 2013 | 10:36 PM
Ecorts1249's Avatar
If this is flashing from the d4 button then u got those codes confused. What im getting is 1,8,13, 14
These are the codes
1-Lock-up solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
Old Jan 15, 2013 | 04:36 PM
There is no D4 button on the dash, but I think I know what you mean. Not good news! TY
Hondalover
Nov 1, 2012 06:00 AM
hammerman
Apr 11, 2011 08:21 AM
embagel
Nov 11, 2010 04:29 PM
bigjayzizzle
Aug 27, 2007 07:49 PM
onesimuschiverton
Aug 1, 2005 03:59 AM
